I thought I had it solved, but it occurred again .
From all OS X machines and the iPad .
First Client starts and directly shuts down again .
Second the Client starts and the black Window freezes …
Nucleus+ Serial #94C691158F16
Version 1.0 (build 227) stable
Version 1.7 (build 710) stable
Version 1.0 (build 12) stable.
OS X Mojave 10.14.6
iPad OS 14.3
I already installed the Roon OS new .
Any suggestions ?
I find it very annoying to buy a peace of equipment for 2.5oo € and a lifetime subscription for Roon without any support . Speaks for itself so far . Does anybody care ?
I’m sure support will get back to you as soon as possible. Note that they generally don’t work on weekends (which is when you posted your support query).
hi, i tested back and forth, its iTunes and Roon .
While iTunes running first, Roon will start, crash without comment .
The OS X displays the usual crash message .
Starting Roon the second time, the black “Quote” Window appears, then Roon freezes .
If you now try to quit iTunes , that freezes also .
In the logs on the Nucleus things look okay — Can you also send over logs from the macOS device? That should have a bit more information about what is triggering that crash on that machine.
Hello @Horst_P_Beck, my apologies for the confusion. For the mac, could you please use the directions found here and send us over a set of logs in that same dropbox folder? Please let me know when you’ve had a chance to do so!
So we can provide the team a better idea of what exactly is occurring during the crash, we are hoping you can provide the logs directly from the Mac. Please see the following steps:
Open Console.app (this is part of mac os x. You can command-spacebar and then type “console” to find it).
Then go into the “User Reports” section, and see if you can find any Roon crashes in there.
For any crashes, paste the contents into a text doc and then send that file over to us here so we can take a look.
Please let me know when you’ve had a chance to upload those files, thanks!
Hello @Horst_P_Beck, and thanks for uploading that information! I have sent it over to the QA team for further review and will return once I have their feedback!
