Hi guys. Im new to Roon. Still on the 14 day trial but im very impressed so far and will probably end up subscribing.
I have a question if anyone can answer please. Im running Roon on my PC which is connected to my Denon X3800H receiver via a HDMI cable from my RTX 3080 Ti graphic card.
Am i getting the best sound using this method or should i connect the PC to the receiver using an ethernet cable from the motherboard to the network port on the back of the Denon?
I prefer a wired connection rather than stream using wifi.
TheDenon has heos streaming I think which isn’t compatible with roon. I think there is a roon extension written by a user that can use heos but it doesn’t work with roon by default.
So, unless you tinker to get heos working HDMI is your best bet.
Edit: here is the link to the heos extension information
Only you would be able to say if there is. If it sounds good to you now I would just go with what you have.
Asking the internet for an opinion is an exercise in futility IMHO.
This “Or will switching over to an ethernet cable from the PC directly to the receiver make a difference?” won’t do anything, it doesn’t matter how you connect them via network Roon won’t see the receiver.
HDMI is the best connection between the Roon core device and the Denon receiver. That will give you the highest resolution your Denon can resolve, (PCM up to 24-bit/192kHz), with Stereo and Multi-channel files.
Ethernet connection to the receiver will be Airplay 96kHz and Stereo.
I have the Denon 8500H with HDMI and Ethernet connections, and while I have used Airplay my preference is HDMI for the higher resolution and Multi-channel playback.
Sorry, not up to date on PC sound cards or drivers.
That would be my guess as well.
I have a NUC/ROCK server setup with the OS and music server software provided by Roon. Nothing left for me to figure out. Ethernet to router and HDMI to receiver.
When/if you move away from running Roon on the PC that would be the way to go. Dedicated music server and no other software/hardware to be concerned about.
Hi and thanks everyone for all the replys and for the info. Still learning. I dont think the Denon has MQA decoding. Im not really fussed about that as im moving from Tidal to Qobuz
According to the manual the Denon x3800h supports airplay 2. But i guess thats just for apple devices.
My desktop PC is in the man cave which is where my setup is and where i listen to music. I will probably just keep it tethered to the PC as mentioned with HDMI.
