connection problem
WiFi
Laptop and tablet
I recently purchased a new laptop and a tablet. The tablet was specifically purchased to run Roon. the tablet was set up by the geek squad so that the tablet goes through my laptop to work. Not only can I not get this to work but, my old computer that I used to run Room won’t play it on my stereo, just my computer. Is there someone I could talk to to get this issue resolved? Thanks Mike Fraser
> * 1. List item
@Mike_Fraser, welcome to the Roon community.
This is the correct place to get support; it’s via this forum. It’d be really helpful if you edit your original post and provide the details requested, so Roon support are better able to assist. Furthermore, please be patient as the forum is really busy following a major new release today.
Community members, such as myself, will also offer help.
In case you can’t see the template used when creating your post, here is the information again:
<!-- Include your operating system and machine info (Model, CPU, RAM) -‐>
<!-- Write below this line -‐>
<!-- Your network gear (model of routers/switches) and if on WiFi/Ethernet, are you using YPN -‐>
<!-- Specify what devices you’re using and their connection types, like USB/HDMI/Chromecast, etc.) -‐>
<!-- Tell us how large your music library is, eg. “30,000 tracks” -‐>
<!-- Tell us about the problem you’re having in as much detail as possible. Screenshots are always appreciated! -‐>
Hi @Mike_Fraser,
I’m sorry to hear about the issue you’ve been experiencing. Have you had a chance to fill out the form the moderators shared in the above post? Greater detail will equip our team to expedite troubleshooting if we know the full details of your network setup, as your description suggests a network setting might be the culprit here.
The most common reason for endpoint dropouts is multiple subnets on the same network. We’ll be watching for your response with additional details about your setup so we can further assist directly, but you can also check some basic troubleshooting steps in our Help Center here: Networking Best Practices
