First from one day to another I can’t hear any sound. It’s not depending from the audio devices. I can see that roon is playing but no sound is to hear. So I want to use my backup. And what should I say, Dropbox is not available in my core. So I want to reconnect without success. I use the code and it doesn’t work.
It looks like Dropbox is still supported for music as well as backups, but neither are a particularly good idea, practically speaking. Even with a great Internet connection, I would not expect Dropbox to be performant or reliable.
You may have to download your backups from Dropbox to a thumb drive and access them locally. I suspect that you’ll encounter timeouts when trying to restore.
Thanks David, I will try this way. Have ever heard about the main problem I have? I see that roon plays the tracks but there is nothing to hear. The database, the favourites etc. Everything seems to be okay. With qobuz direct all the devices are working.
I had that problem once on one endopoint where I was running SoundSource (on macOS). Quitting SoundSource solves the issue. Have not experienced that on other endpoints.
