Mac Mini (late 2014) Big Sur
2.6Ghz i5 8GB RAM SSD
Sagemcom Model F@ST3896 UM
Netgear Nighthawk AX4200
Direct ethernet connection to Endpoint
Sonore opticalRendu via TPLink fiber media converter fed via ethernet direct to router.
11,727 tracks
I get random 4-5 second audio dropouts no matter if I play direct from Roon or through HQPlayer - doesn’t matter if it’s Qobuz or Tidal. It’s terribly frustrating. This happened probably 10 times in the last hour and does so on a daily basis. I can’t get a more direct connection to the internet/router, and both are very fast. I want to love Roon, but this is unbearable. Can someone review my logs to see what sort of errors are causing this?
Same issue with local files. I talked to Small Green Computer today and they think the Mac mini is the problem. I ordered one of their sonictransporters to see if that fixes the issue. With a 30 day return, can’t hurt to try.
Thanks a lot for letting us know of this and for being this dedicated in finding a solution. We’d love to help in any way we can.
I wonder, if you try streaming music (from your local files or TIDAL/Qobuz) to System Output or one of the remote devices, do you experience the dropouts?
Hi @beka I was speaking with Sonore yesterday and they thought the issue was my older Mac mini running Roon as core. I ordered a new server which should be delivered this next week. I’ll post what I find out after I get it in my system.
