Windows Server 2019, Ver1809, Intel i7 -8.700@ 3.2GHz, Roon Core 1.7 (build 667)
Ethernet, 1Gbit/s WAN connection
Merging HAPI via Ravenna
It has already been reported, that certain devices output a short noise burst when start playing a track. So far, this has never been an issue with my setup. It has never happend so far. Since a week I have changed the convolution files used. I am now using 264k tabs instead of 64k. Consequently the files are much larger. In the begining this hasen’t been a problem with Roon. Since a few days I am experienced a small burst of noise when swithcing tracks. This can be cured with a re-start of the Roon Core.
Thanks for sending the filter over @Ralf_Hoellmann, I have requested our technical team review it and as soon as I have an update from them, I will let you know!
has anybody got convolution filters being processed with Roon, which have got more than 266k tabs?
I have tried 524k and Roon does upload them into DSP. However, several error messages are produced when start playing music. Either “Too many interferences” or “can’t play audio”.
I merged your two threads so that we can have all the information in one place.
Your case is with our technical team for review, I have just messaged them for a status update.
I’ll let you know as soon as I hear back, thanks!
thanks to the great support of Uli Brüggemann (Acourate Software) the last issue has been ressolved: I can now process 524k tabs with Roon convolution with 8 different channels.
The solution: All eight *.wav files need to have EXACTLY the same number of tabs.
However, the noise when switching sample rates hasn’t gone away!
524k taps is very large. I’ve used filters with 132k taps for a long time (2ch, not active xover) with no problems at all (Audiolense). Is there any advantage in using so many taps?
Yes, there is. The main purpose of equalization within a room is to eliminate room modes. Unfortunately, they are (mostly) very narrow bandwitdh peaks/ dips. While the ear can interpolate the dips, the peaks create the typical in-a-room bass quality…
With 132k tabs you can achieve a theoretical 0.36Hz resolution at lower frequencies. The ideal would be better than 0.05Hz. With 524k you already get to 0.09Hz.
Just make a comparison with two filter sets: The difference in bass performance is remarkable!
Does the noise when switching sample rates only occur when you have the Convolution filters active as well? Can you share two screenshots of your Signal Path when the issue occurs (before and after)?
Thanks for the additional information and convolution files!
I’ve requested the team try to test for this issue in the lab.
Once I have further information, we’ll reach out again!
