I am about to setup my pi as an endpoint (I have the roon core on a server) and was wondering if the cover art and track info is displayed on the hdmi output? Are there options to customize this?
Alas, not possible. It would be a great feature, as has already been pointed out:
Thanks for the quick response.
My request is slightly different. I would like the pi to be used for both the audio out and displaying the now playing info on th tv.
Thanks to the folks at Roon, this is the first music software that is truely usable to find, playback, explore and rediscover my music library. Great job and keep up the good work.
What software are you running on your RPi?
I’m using RoPieee and it seems it supports the RPi Touchscreen to do this, but not the RPi HDMI output to display the information on a big screen TV. Would be great if it did because then you could see it across a large room.
I’d also like to see What’s Next being displayed as well.
