Hi!
I am using 2 roon endpoints at the moment running ropieee XL. Since some time on one endpoint (both are running on the same version) I get a cracking noise between 2 songs. I tried to turn of the fading between the songs, but this did not change anything. The noise is not between every single song, but very often.
Has anyone an idea what I can do?
Before this issue started, this endpoint was running months without any problems.
You may want to let the community know, which HAT or USB DAC you’re using.
That said, it could well be due to sample rate changes.
And if that’s the case, using Roon’s sample rate conversion to upsample all material to the same rate would probably cure the symptom.
Try changing “Max pcm rate (power of 2)” to “Max pcm rate” otherwise you will still get a sample rate change when switching between 44.1 and 48 material.
You could also check the Roon signal path between tracks that click and see what sample rate is being decoded.
Hi there!
Sorry for the late response…got my first child these days
I did some changes now and will listen if the craxx are still there.
1 turend of USB in Ropieee. I do not have a usb aditional to my HAT
2 switched the DSP to “MAx pcm rate”
3 switched MQA to “no support”
4 Device volume is working, so I kept this
5 Ropieee XL - Airport is enabled. I kept this for the first try
I will report after some time listening…thanks for now for that plenty hints on this!
…but I still wander why this was not a problem from beginning… I was using my setup for more than a year without any issues…!?
Well, there’s quite ‘some stuff’ involved. A lot of software, a lot of hardware.
As this is about a HAT… can you test without device volume? Then you can rule out that it’s this part that is generating the noise.
It seems the cracks are history!
I guess the DSP settings was the solution…
And I guess I know why this issue popped out - but I am not sure - maybe it came because I changed my tidal subscription. Some songs are in master audio and some not…maybe this caused the cracks.
I will test some more to find out the exakt reason, and report here!
