Roon and Dante protocol. Is anyone using it? On the Audinate.com website I purchased the Virtual sound card and a Dante Out Xlr cable. The dynamics seem very good even if the bitrate. does not go beyond 24/96. There is the advantage of eliminating the pre audio and managing the music directly with the roon volume also with the dsp
I just purchased Void cyclone speakers and the Void Bias Q1. This is a Dante enabled amp. How did you setup Roon & Dante combination? Do you run DVS on your Roon server? Thx!
