Full form submission What’s happening? · I'm having trouble connecting to Roon
What type of connection issue? · I can't connect to Nucleus
Describe the issue Our Demo System is Down after attempting to Update Firmware. No Power Light, but Network indicator is lit?
mjw
April 24, 2024, 3:07pm
2
What device are you running the server on? Furthermore, if you’re a Roon Nucleus dealer, you should have a dealer contact email.
Hey @John_Marshall ,
Ben with the support team here, I wanted to check in and see if you were able to get things sorted out, or got in touch via our Dealer support? I didn’t see any existing tickets so I though it important to triple-check.
What are you running your Roon Server on?
system
(system)
Closed
May 14, 2024, 11:22pm
5
