After upgrade to latest version of Roon, the playback is not stable, playback (44 / 16 bit) always stop at the last few sec of of the song, noise pop up frequently. Using ethernet connection.
As this is a support issue I’ve moved it to the support thread
Make sure you’ve either set the ethernet port to 100MB/s (at the data switch end, if possible) or switch to Wifi (if an option). There is currently a known issue with Devialet and 1Gb/s switch ports, and perhaps this is your issue.
Does this issues affect both Expert and Export Pro?
Hi @Stefan_Woll,
As other users have mentioned here we are currently investigating an issue with Devialet regarding the RAAT implementation (main thread here: Audio file loading slowly since Devialet RAAT).
The 100 mbps workaround mentioned is not meant to be a permanent solution but rather just a tool to see if this is the same behavior that we’re aware of and discussing with Devialet.
Thanks again for your report here and I’d definitely suggest keeping a close on on the main thread I mentioned for any new updates.
– Noris
