Difference between artists in Tidal and in Tidal inside Roon
Hi,
I have favorite artists in Tidal, and when I am inside my Tidal collection with Roon, I don’t see the same.
Example:
I have an artist with 2 albums in Tidal (Corsu - Mezzu Mezzu). Each album is normal, with all the songs described.
With Roon who shows Tidal, only 2 songs of the 2 album are proposed.
It’s not recent albums, so I think the exchange of datas between the platforms may have been operated.
What’s the problem, and how to fix it?
Read you soon :wink:
A favourite TIDAL release is added to your Roon library. However, a Roon favourite is not equal to a TIDAL favourite. Only releases and tracks are added to Roon; when a track is added, it will be displayed under the release.
I don’t speak about Roon favorite.
I speak about an artist with 2 albums in Tidal (which I put in my favorites, but it’s not the problem - favorite or not ; I will change the title of my question in removing favorite) and when I click on Tidal in Roon menu, then I click my collection, then favorite artist, then this particular artist, it shows only 2 tracks of the 2nd album, not all the tracks, and the 1st album is not visible.
Tidal :
Roon :
The compilation is one of these albums which is in my personal lybrary.
I don’t understand why Roon don’t show the same things… because I guess that it’s the reflect of my choices in Tidal.
You seem to have the library icon selected. If you turn that off do the other albums appear
No, it was not selected.
If I do that, the library icon becomes blue, and I have only the album shown in compilations :
i don’t understand your reply.
I speak about Tidal in Roon menu, not about my library inside Tidal.
I do continue to hope thati it would be the same proposal, because Roon extract the datas from Tidal, in taht case.
Or I will be curious of an explanation, why I ask here.
I confess I had to try this to understand
You did like the artist in tidal app
It does not appear on roon tidal tab in My Tidal Collection
I do not use the tidal tab in roon but still I’ve check for my tidal artists and it does not happen like this. Do you have others with this problem?
Going further I have added the albums to my library (hearted them in tidal app)
They show up in my library but not as Corsu - Mezu Mezu but as various Artists. So maybe that is why they do not show in the artist page. I’m not very comfortable with metadata understanding in roon, maybe other can explain why this is happening
Screenshot 2023-05-01 at 17.50.26
I made the same conclusion.
The albums are “hearted” for me in Tidal, so I can see thme in my lybrary, in ‘versions’ tile.
But I do want them also in Tidal navigation inside Roon.
I’ve never edited tidal metadata to prefer roon edited but maybe if it is just this one case you can do that.
Nobody has another idea ?
Or someone from the support team ?
