QNAP Tx473 8GB Seagate 240GB SSD Roon database; 2 x 6TB Seagate HDD RAID 2 storage for music ; 1 x 6TBB Seagate HDD as separate backup vol.
NVidia GeForce GT 1030 graphics card.
TP-Link Archer VR2800 router connected to Virgin Superhub set as modem mode.
All hardware is hardwired via Cat 6 and Cat 5e.
Meridian 210 streamer connected by coax digital cable to Cyrus 8XPD QX integrated amp/DAC (plus power amp and power supply) playing through B&W 805 speakers.
Also in parallel I have Meridian Sooloos system Control:15 in one zone and MC200 in the specific room concerned connected to above Cyrus amp via coax cable.
Problem: when I play a Song from a FLAC file of ripped CD on my Sooloos system the Cyrus amp displays it is playing at 88k sampling rate. If I play the same song from the same CD stored on my NAS drive via Roon the amp displays a sample rate of only 44.1k. If I swap the inputs on the amp, the Sooloos still displays 88k and Roon 44.1k
Why is this, is it a genuine phenomenon or should I ignore the display?
The max sample rate on the Roon / Meridian 210 setting is 96k in line with the amp spec.
Anyone know whether I need to change any other settings?
I have only just changed from wireless to wired connection on the 210, but the sample rate is unchanged.
