PhilG
(Phil G)
June 13, 2020, 2:52am
1
Environment / Setup
Core version 1.7 build 555
iMac 2.5 GHz Core i5 running MacOS Sierra 10.12.6 with 12GB memory.
Apple wireless Airport Extreme
Endpoints using Chrome, and Sonos
Hello,
When running Roon on either my Windows 10 laptop or iPhone XS Max-2, occasionally I will not see any audio devices present. See attached screenshot.
When I get this issue I will usually shot down the core running on my iMac and restart, or it will just resolve itself without taking any action.
I appreciate your help.
Thanks, Phil
Rugby
(aka Daniel or Big Dan)
June 13, 2020, 3:25am
2
Usually that is caused by firewall settings. Try turning off the firewalls and see if the devices show up in the Audio Section.
Note: edited to correct errors caused by using a phone to type.
wizardofoz
(Mr Fix It aka The Wiz)
June 13, 2020, 4:08am
3
Also see https://kb.roonlabs.com/Networking_Best_Practices WiFi for a core machine and Apple networking both get an orange flag
PhilG
(Phil G)
June 13, 2020, 4:18am
4
Hey Guys,
I am wondering if it’s a low memory issue on my iMac Core? I just shut the Roon Core down and restarted it and now I can see all devices. No network changes were made.
Thanks, Phil
noris
June 15, 2020, 4:31pm
6
Hi @PhilG ,
When this issue occurs, what does your Roon Settings -> Audio
tab look like? Are your Sonos Airplay zones missing as when when this occurs?
PhilG
(Phil G)
June 15, 2020, 5:38pm
7
Hello,
Totally empty. I was starting to think that maybe my iMac / Core is sleeping but I if that was happening I would get Core is not available which I’m not getting.
Thanks, Phil
Rugby
June 15, 2020, 5:40pm
8
Have you tried turning off all sleep settings and just letting it run for a day or two and see if it makes a difference?
PhilG
(Phil G)
June 15, 2020, 9:35pm
9
Hello,
I actually change it last night and I haven’t see the problem today. I’ll keep an eye on it.
I appreciate your help and support!
Thanks, Phil
system
(system)
Closed
June 15, 2021, 9:35pm
10
