NUC 8i3BEH ROCK
OS: Version 1.0 (build 256) production
Server: Version 2.0 (build 1259) production
ROCK hardwired to router via switch
Endpoints on mix of wifi and cable
NA
~31,000
Split between Qobuz tracks and local (mainly) FLAC files held on internal HDD in NUC.
Looking at The Flaming Lips artist page the discography does not properly show the albums that are in my collection.
I have two versions of Yoshimi Battles the Pink Robots which are both locally held sets of FLAC files. You can see them here on the Artist Overview page correctly;
If I do that it appears as a library album. If I click again it goes back the original sate with the album shown as Qobuz only. But its the only album affected. Is this because of non-equivalent versions or something?
EDIT: I wonder if it is because my album version has the ‘24 bit’ ‘Version’ string applied. This is a hangover from my days before Roon. The album folder name is marked [24 bit]. Having said that the album is identified by Roon correctly so it ‘should’ be treated as a prefered library title I think ?
Yup so that was the cause. Because one of the albums had a Version set it was causing the matching used on Discography to fail for some reason. I edited the offending album version to remove the value set for ‘Version’ and now it displays properly
