I have different power cables here and thanks god none of them has an influence on the sound of my gear.
They only do what they are build for, transport the power to the devices. Nothing else and I like it.
I have the Next Great Idea. How about we all pitch in a few hundred $$ and create an Audiophile Power Company?
We can charge a 10x premium per filtered, cryo-treated kilowatt. It will be directional, and then we can charge for different levels of blue, red, and black electrons.
The electrons will have to burn-in before the improvements will be noticeable.
Do you use a conditioner or regenerator? I know you think the power management thing is a bunch of hooey, but I have two regenerators. They certainly keep the line noise down. Line distortion is measurable.
Hi Robert. I have two Monster Power line conditioners, which I got quite cheaply or I wouldnāt have bought them. Mostly I was interested in using them as surge protectors and the bonus is they show the ridiculous over-voltage that our local power company puts on our line.
I did hear the demo at my audio store where turning on and off the conditioner was demonstrated by static coming from an internal speaker in the demo unit being silenced.
However, I honestly do not detect any difference in sound quality when these units are in-line. To me they are just fancy surge protection power strips.
You might want to demo a regeneratorā¦
Iād rather just replace any faulty equipment that is so flaky that it canāt handle mains power. Effective power supply isolation was a solved problem 50 years ago.
Have you demoed a regenerator? OK either way, but regenerators are very useful items. Iāve bought two of them. I have good quality equipment and the power source is where things start. The equipment downstream isnāt flakey, but improved by a cleaner source of power. Itās no different in concept than cleaner water or cleaner air.
Welcome to the forumsā¦
What kind of over voltages are you getting? I had a similar problem, and reported it to SCE, my electrical provider on two occasions. One case involved a faulty part at the local switching station intended to boost voltages during periods of high demand. Problem was the faulty component wouldnāt disengage, and 135 volts incoming isnāt a real good thing. The other time was incoming of 127 volts, which only a touch high but in excess of the maximum voltage specs.
My mains power is within spec and all my equipment is operational so I would not see any difference from using a regenerator. If you have really dodgy power or flaky components I can see how one might be useful.
Well you might hear oneā¦but as you havenāt tried how can you say either way. I havenāt tried one either yetā¦so I am not about tell anyone you wont benefit just because you think your power is fine.
How much line distortion do you have? I have very good power with respect to distortion. Around 2% incoming. Outgoing regenerated is 0.1% or 02% depending on what day is it.
If you donāt need one great, but you canāt assess the benefit since you have not tried one. 30 day free demo if youāre in the US from PS Audio. If you tried it, and thought it was worthless, then nothing lost. You could return it and have gained the experience of trying one.
FYI, very few get returned.
Go over the PS Audio forums and ask a few questions. I think you might be surprised.
Just out of curiosity, what do you use to measure the THD on your AC power line?
PS Audio Power Plant regenerators. P12 and P5.
I also have a PS Audio Quintessence conditioner (no regeneration)
The P12 and P5 are on a 20 amp dedicated line.
The Quintessence is on a 15 amp shared line.
Quintessence pictured above - THD 1.8%
So youāre relying on the device itself to tell you what a great job itās doing?
Yes, I do utilize the equipment just as you saidā¦just like I rely on my speedometer to measure how fast my car is traveling, and my watch to tell time.
The ears confirm better performance with the equipment versus not in use.
I, periodically, check my watch against other clocks to make sure that itās actually telling me the correct time (and is not running too fast or too slow).
YMMV (literally).
Do you verify your speedometer?
Distance in miles / Time in seconds x 3600 (answer in mph)
If my speedometer were significantly off, thereās a traffic cop who would swiftly set me straight.
