#Roon Core Machine
ROCK
NUC i7 16GB RAM
SSD
Attached drives with music: LaCie 5TB and Western Digital SSD 4TB
Path ROCK>USB>Matrix>I2S(HDMI)>PSAudio DSD DAC
I removed drive to add new ripped files. Reinstalled drive and DSD no longer works correctly PCM is fine. I hear low volume of song with white noise.
The Core has had reinstall of the OS and multiple reboots no change. DSD shows correct rate on DAC and plays fine from transport. Roon has native DSD and setting Roon to DoP output doesn’t seem to generate audio or correct bit/sample rate on DAC.
The DOP isn’t an issue as the Matrix isn’t passing the signal I would have to connect USB to the DAC directly as I recall.
If I convert to PCM the DSD files play. Roon doesn’t like native DSD right now. @noris
