Brian, I really appreciate this. Please let me know what you find out or if I can do anything to help
@Eric Hi Eric. I finally got the SOSE to show DSD in the settings. I connected my MacMini and made sure everything was there in that which it was. I selected DoP there and then went back to the SOSE. It showed after I set the volume to “none (100%)” in RoonReady settings and the DAC to max volume. Now, how do i adjust volume with this setup? I do not have a preamp and the Veritas has a volume control but it doesn’t work with these settings. Thank you so much for your help. I have been trying to figure this out all week
Robin
I solved the problem by connecting the SOSE to my Oppo UDP 205. Works like a charm. There is definitely something going on between the SOSE and the Veritas. I get correct settings on everything but that combination
