I got a Pi and a DSD 128 DAC (Hegel HD12) when I play all formats FLAC MQA and so on It works fine but when I put on a DSD track no sound. The DAC indicates DSD 128. If I change to the other settings for DSD np sound swell.
I have my core on an old Macbook Air just connected to wifi 5Ghz. Can it be that I need to wire the Macbook Air? Or is it just to old and slow to cope with DSD?
I think software in the DAC is able to recognise DSD128, but can’t play it. USB Driver on HD12 DAC is same as in 360 amp and 360 seems to be able to process DSD128. Kind of strange, but that is the only explanation I can think of…
Sorry, I forgot you’re not using Windows based endpoint. If HD12 is connected to Pi, it does not need any driver. Bottom line is that HD12 does not support DSD128. Doesn’t matter whether endpoint is running Win/Mac/Linux OS.
Try wiring your MacBook to your router to discount a potential wi-fi problem.
My MacBook skips and stutters with hi-res playback, even 192/24 via wireless. But… my endpoint is also wireless, so there may be a problem with 2-way traffic at hi-res over wi-fi.
With my core (MacBook Pro) wired, and endpoints wireless, it works fine.
I haven’t tried DSD though, as my endpoint doesn’t support it.
I’m using a ROCK as a bridge connected to a Hegel HD12 DAC. The ROCK recognise it as a “Native” DSD device and I set up the Max Sample Rate (DSD) to “Up to DSD64” as the DAC only supports this.
But if I try to play a DSD music I receive a blinking “DSD128” message on the DAC’s display (even if I try to play DSD64 files) and there is no sound.
its pretty easy to find a windows home small PC - nothing exotic needed to run Roon Bridge for a fully supported windows ASIO driver supported endpoints. setup with auto login and a VNC like teamviewer or anydesk and remote in to admin it - (Windows home doesn’t support Remote Desktop) even an older win7 Celeron on a run out sale (blackfriday/cybermonday) should be cheap enough. Wired LAN of course is best.
As I mentioned to Peter, I would not like to use Windows for Roon. I’ve got a pretty decent endpoint (i5 / 16GB RAM / SSD) but I would not like to deal to optimise the OS for audio as ROCK already optimised for Roon.
Instead of this maybe I have to looking after another DAC. Is there any recommendations?
Perhaps other members here who will tell you their favorite USB DACs. For each of them you will have to search the forum for Linux / ROCK native DSD compatibility if you care about DSD256 and determined not to use Windows - generally those using Amanero USB module won’t work with native DSD, those XMOS based typically do but may suffer another problem with bit depth changes. Or you can use a Roon Ready network player such as those offered by the company I work for.
