Ubiquiti Networks UniFi Switch 8 Managed Network Switch Gigabit Ethernet, is the only thing between my core machine and bridge.
Asus Xonar U7 connected with USB, outputting stereo to ATI amplifier and a pair of Magnepan wall mount speakers, and LFE to SVS subwoofer
I had my system setup using the DSP to send the signal from the left and right channels to the subwoofer with a low pass filter on the LFE channel.
I had to do this a little different, I think it’s because Roon has a different map for the channels compared to the Xonar DAC. I set up a procedural EQ and added the mixing rules for the LFE channel. The only way I could get the LFE to work is by mapping the left channel to the LFE and the right channel to the rear right speaker, if I set them both to anything else I got no signal on LFE.
The latest update lost my DSP settings and I restored a backup from the 15th and it did not restore my DSP settings. Last night when I tried to recreate the speaker mix, I got the error “unexpected error communicating with audio device”. This morning I am not getting that error, but I also cannot get the LFE channel to work.
I understand that the DSP needs to be reconfigured, if you reread my post you will see that I already reconfigured it but I no longer get any LFE output after the update. It worked before the update and with the same settings now it doesn’t work.
Why do the same mixing rules no longer work? How do I get 2.1 sound working again?
To add some info, I noticed that it looks like I saved my previous DSP as a preset so I activated it but it still doesn’t work. This DSP preset worked before the update and now it doesn’t work, and the only thing that changed was the update.
