USB goes to Qutest via Raspberry Pi over network and Optical goes from MacBook to Qutest directly.
The reason I do this is I want to use the Qutest for video call and content editing too. Connecting directly benefits the latency significantly. The sound loses clarity a bit but I can compromise for those use cases.
The problem here is when you select Qutest on DSP screen in that case, you have the duplication which should be a bug.
That’s strange, you shouldn’t be seeing the duplicates on that page.
What were you doing before the issue occurred, switching between the two zones in the DSP menu?
If the issue re-occurs, can you note the time + date of the occurrence and which Roon Remote in use?
Can you please use these instructions to send me a set of your Roon logs when you are in this state? Please send the logs from the Roon Remote, not the Core in this case.
Thanks again for sending the logs over. I spoke to the team regarding your report and we were wondering if there is any set of reproduction steps that you could share to get into this state?
Which zone did you switch from? Is it reproducible each time you switch from that zone?
What zones are you grouping afterwards? Can you list steps please? Thanks!
