Utilizing Roon Essentials via Elac Discovery. I have also been in contact with their support team, but they have been unable to resolve the issue.
I currently have everything hooked up via ethernet from my home modem/router. The modem/router is an ARRIS SURFboard from 2015. All connections, including the Elac Discovery running roon essentials and the KEF speakers, are made directly to the router.
I am using the KEF ls50 Wireless, connected via ethernet. I have also ensured that the speakers have the most up-to-date firmware update so that should not be a part of the issue.
Every time I go into Roon Audio settings to try an locate the KEF speakers they are not available. I have tried resetting everything in the chain (modem/router, Roon essentials, ls50W speakers) and nothing seems to work. I have tried to look at my network settings, and the KEF speakers have an assigned IP address and the modem is locating them. However, for some reason Roon still never identifies them. If you could provide any suggestions or assistance it would be greatly appreciated.
Thank you!
