Error Codes 502 and 504 in Arc on Zen WiFi AX Model T8 in AP Mode, UPnP Setting Missing (ref#QOT0XJ)
Hi @Steffan_Dye,
I agree in that you’re close! And a massive thank you to @Robert_F for the assistance here.
A few things to check:
  1. In your iOS settings> Roon Arc> have you allowed access to your Local Network and Cellular Data? Both should be enabled.
  2. With Roon Server running on your windows, can you confirm there are no firewall restrictions with Roon? With your Roon Remote app functioning properly, this seems unlikely, but always worth a triple-check.
I’d give both your windows a hard reboot, as well as your router potentially, and see if you still run into issues connecting.
It is working now. Thanks ya’ll for the help. @Robert_F, you are a very generous person. Thanks so much for the help.
Fingers crossed something doesn’t go wrong and I have to come back for more help.
With appreciation,
Steffan
