Hi @Claus_Jensen1 — You can enable System Output by going to Settings > Audio. From there you can choose that as your endpoint from the Zone Picker and play directly to the speakers of your computer.
Yes, the same noise occurs when I play the 96/24 stream out of my windows laptop directly.
It happens about 8 minutes into the stream (Berlioz Symphony Fantastique with Valery Gergiev and the London Symphony Orchestra.
Found the culprit! The file that I referred to above is evidently corrupt, perhaps due to the transfer from the original SACD by LSO.
You can probably duplicate this to verify, if you are interested.
In any event, Roon plays 24/96 streams from other record labels without a hiccup - and I am again a happy camper.
Hi @Claus_Jensen1 — I’m glad that things are working for you now! Please feel free to reach out if you ever have any other questions or issues. Happy listening
