I just purchased a Fire HD 10in 2019 to use exclusively as a Roon Remote. Is there a way to keep the Roon remote open so I don’t need to go to the lockscreen when it goes to sleep?
Go into Settings - Setup - you should see a keep screen awake option. For my IPAD it keeps the screen on when Roon is in the forground and uses the device options when in the background.
