VLAN 30 for Roon Nucleus+ and Naim ND555
VLAN 100 for Macbook Pro (used as remote only)
Naim ND555 (streamer and audio output) on VLAN 30
NA
I have a dedicated VLAN for Roon Nucleus and Streamer for network packet isolation (VLAN 30).
However, my Macbook Pro which is on a separate VLAN (VLAN 100) is used as a remote for the Nucleus+ in order to change track or view my music. What ports are required to operate the remote on the Macbook Pro and successfully communicate to the Roon Nucleus?
VLANs use separate subnets, and Roon cannot work across subnets. Changing firewall rules will have no impact on this. You must keep the Nucleus, Remotes, and Bridge devices on the same subnet.
