Fixed volume quieter than device?
Roon 2.0 (1244)
QNAP TS=473 Ryzen RX421ND 8GB ram
Netgear Prosafe MS510TXPP switch > Sonore OpticalRendu > Schiit Yggy DAC
59000 tracks
###Descriptipon Of Issue
Hi,
I’ve noticed a significant drop in volume when comparing fixed volume to device. Fixed is quieter. As I am using a passive preamp this reduction in volume is a problem. Can anyone think of a solution other than using device volume or getting an active preamp?
Thanks, Geoff
Thanks for the suggestion. I don’t seem to have that option :frowning:
