After some light DSP (volume levelling) I can set the Roon output stream to my CA CXN v2 in 32-bit resolution, but the CXN has a 24-bit DAC. So will the CXN downgrade to 24-bit anyway before DA conversion ? In that case I guess it’s best to have Roon send a 24-bit stream in the first place.
I’ve very briefly been AB testing this and can’t really hear a difference. I just want to make sure the setup is optimal.
Thanks to anyone who can shine their light on this.
That looks quite happy from a Roon perspective. Don’t worry too much about what the CXN chooses to do, whatever it does will be to its best advantage. If you can’t hear a difference then go with 24 bits for reduced bandwidth loading.
Thanks and yes, I’ve settled with 24 bits for now for the reason you mention. I did send the question to CA support, just to see if they come with a more detailed answer on this. Will take a couple of days before I get an answer I guess.
