Roon can’t find my B&W Formation Edge. Ally other audio devices show up except Formation Edge which was working fine and then all of a sudden it disappeared. I am using a MacBook Pro as the Core. I can connect to the Formation Edge using iTunes and Airplay but not from Roon. Same from my iPhone. I’ve tried resetting the Edge. Roon is not showing Formation Edge as an audio choice on my mac or my phone. Please advise how to fix this.
When my Flex has disappeared from Roon I have turned off my Router, Core and the Flex and in order I have turned on the router, core and Flex and that has done the trick.
Hope that helps you.
Also, I take it that you mean Wedge and not Edge?
It’s a Wedge! I reset everything as you suggested and it works! Thanks Mark
