Is Roon Server running?
· I see something else
When you try to connect, what screen do you see?
Please try to restart your Roon Server by closing the Roon app in the taskbar or rebooting your Roon Server machine.
· Roon Server is connected by *WiFi*
· *MacOS*
· *Mesh networks*
You mentioned a mesh network in your setup. Certain common mesh networks might require slight reconfiguration to support Roon.
· Eero
Click below for next steps with an Eero mesh network.
· I still need help.
Over the past several months I have frequently had to reboot the entire system. (router, EERO, Sonos, BluOS, etc.) to find my audio devices. I have made my wifi discoverable. It seems to happen after any one of the elements in the chain update. Roon/Sonos/BluOS/EERO/etc. Making me consider one of two options if this continues. Stopping my Roon subscription or going to a Nucleus One. (however would want to be sure I wouldn’t have the same problem just with another piece of hardware/software in the chain…..
EERO, Sonos, BluOS(NAD M50.2), MacbookAir
