Cyan 2 has audio output as the only signal out, is it possible to utilise that as an input for an headphone amplifier? Tried to do this with a Matrix mini-i pro3 without success. Any chance for a different approach?
Cyan2 analog out to an amp’s analog in?
Tried that with Matrix mini-i, as stated in post.
The Matrix Mini i3 doesn’t has any analogue inputs (only two outputs) and so you can’t use it with the Cayin2.
I have a mini-i pro 3 and a mini-i 4 and both have an RCA analogue input (as well as optical, Toslink and USB). I have used both for TT input and both work perfectly with line level input’s.
Thanks for that. They certainly bury the headline. In that case I would not use it as an amp for the Cyan2.
