Roonbase.
Roonbase.
In Norse mythology, the runic alphabet is attested to a divine origin, so how about, Roonic, Roons, Roonstone
Hi,
RoonBox!
rgds
Mark
What about âRoonifierâ, because it Roon-ifies the Device/Speaker/Endpoint/Zone with Installing RAAT.
Roonlink
Cheers
RoonAudio or Roon AudioPlayer
Best,
Mark
Roon-Fi
Roonity
RoonConnect
RoonConnect I like too. It is the software you use to connect roon to your PC
We already have RoonServer, so next should be:
RoonPlayer (as in CD player, but pretty old style, so what about âŠ)
RoonStreamer (i really like this one)
Hi all,
This is how I see the Roon âfamilyâ :
*The Database is optional and is only required when not using Roon Server âŠ
In which case it operate as a Roon Remote.
Though I donât really like the term Roon Remote and would prefer Roon App or Roon Client.
Also as far as possible I donât think these should be separate installation downloads; one should only have to download âRoonâ (for your given device) then it should prompt with the installation options.
I like the Roon family architecture of Carl and can be copied right away in Roons manuals. So, RoonClient.
RoonooR or
iRoon
or
Rozon
I really like REShamanâs suggestion of RoonMate and dbtom2âs PlayRoon.
Hereâs a few others
RoonLanding
OvertheRoon
PaperRoon
RoonOverMyHammy
Hmm â my reaction to Connect is âstuff that I use to connect to something.â
So RoonConnect would be the name for the remote that I use to connect to the RoonServer, not the thing that the RoonServer uses to connect to me.
Like the distinction between upload and download â I have seen unconventional usage, but commonly âdownâ is to me.
@Carl Yes, that makes sense. And I very much agree with the single download (as far as possible), making these installation options. Actually, they are configuration options, they can be changed after the installation (e.g. a remote can take over ownership of its own database).
@ncpl What I meant by questioning the need for a ânameâ is that branding is a very sensitive and tricky subject. Iâm an engineer, not a marketing guy, but I have learnt some of the naming and branding principles over the years.
I think there should be only one Brand and that is Roon.
The other things need descriptive labels so we can talk about them, but that doesnât make them brands. So RoonServer is a fine descriptive label but it is not a brand, so it isnât really a âNameâ. And we have to be very careful in understanding what RoonReady isâŠ
A few examples. In storage, SMB is the name of the protocol; while Microsoft is a major user of it, it is an industry standard protocol that many players implement so therefore it is important it has a name.
But for the rest of it: Windows Server is a brand. File Server is a server role, you donât license Microsoftâs File Server, you license Windows Server and then include the File Server role during installation (or later). So File Server is something that needs a descriptive label so we can talk about it, but it is not a brand.
Core Server and Nanoserver are not brands. And they are not SKUs either (Stock Keeping Unit), i.e. they donât exist in the price list. They are deployment options. Standard Server and Datacenter Server are SKUs, i.e. you can license them and they have a price. But they are not brands. And the deployment options (Core, Nano) apply to both.
Complex, sure. But important. And Roon needs similar thinking.
Brand: Roon
Branding label important for partner relationships: RoonReady
Roles: Roon (the full thing), RoonServer, RoonRemote, RoonZone
Technologies that are typically not discussed with customers: RAAT
Something like that makes sense to me.
(And I imagine there will need to be another variant of RoonReady: at the moment companies license only the RoonZone component, but if somebody licenses the whole thing, with server and user interface, what will that be called?)
RoonAudioEndpoint ?
How about Roondo?
I guess it wonât be:
RoonPod
RoonBox
Roonos
RoonooR
RooEnd
How about something that plays on the fact that it can be used on old kit?
Roonewable
Or
RoonVR
RoonVirtual
Roon-Anywhere
RoonSoft
Cheers
Tom
Roonify
For obvious reasons.
Hi @AndersVinberg
Thanks for explaining your thinking here. I am 100% in agreement.
It needs a descriptive name not a funky new brand.
The description (IMHO) needed is already made
and I would use it along the lines that you and @Carl have suggested
cheers
