Hi, I am relatively new to Roon. Just acquired a NAD M33 and would like to put a set of outdoor wi fi speakers on our deck. Would like a decent quality speakers.
What are my options? I have a Sonos setup in the house, in addition to my main speakers. Are there outdoor wi-fi speakers that are Roon certified that I can use as an endpoint? Or am I better using the spare speaker outputs on the M33 and select those speakers in the M33 when I would like music outdoors? Thank you for any help.
I have a pair of Sonos Play 3ās outdoors but theyāre under cover.
When I lived close to the coast I had a set of speakers outdoors that were very exposed ⦠specifically for that application I chose a pair of marine speakers and ran speaker wire from an amp indoors.
It really comes down to just how exposed youāre talking and what sort of sound you want. Thereās some very good portable speakers on the market that are happy in the elements.
Iād run marine speakers off the NAD in light of no other info.
Thank you. Arenāt there limitations on what the Sonos can reproduce?
Also I donāt need anything permanent that will survive the weather. Iād be happy with something portable I could place outside when I plan to use them.
Friends, Iām searching for a Roon Ready outdoor wifi speaker. It can be battery or ac powered, and Iād like at least some water resistance. Think poolside, or occasional garage use when tinkering on bicycles. Any suggestions?
Does it have to be Roon Ready or would Bluetooth Roon from an accompanying phone or tablet be acceptable? Just asking as there arenāt stacks of RR portable speakers on the market.
Well, it doesnāt have to be Roon Ready/Tested; itād just be neat. Iām a lifetime Roon subscriber, so Iām all in at this point. A good quality Bluetooth from iPhone/iPad/MBP would be fine. Thanks for asking!
Any of the JBL outdoor units.
They are Chromecast so Roon sees them as endpoints.
I use one around my pool on WiFi and it works well enough with regular 16/44 streaming.
I think mine is a JBL Pulse, but I think any of the Pulse or Flex series should work fine.
Just check it supports Chromecast.
Now you did specify Roon Ready, which I donāt think Sonos is, however, their integration within Roon is, in my experience, unbreakable.
They cannot be grouped with RAAT devices, however, all the Sonos devices can be grouped together within Roon (in case you wanted a Sonos Move on all four corners of your pool!), or alternatively, they can be grouped as Airplay, and then you can group non-Sonos devices (including RAAT devices with Airplay) as well within the group.
This image shows a current configuration I have illustrating both types of grouping.
A chromecast embedded portable speaker for a direct Roon Endpoint
or
An old phone with Roon installed going out the headphone plug to an Aux in on a Hyperboom. Alternatively, it could be bluetooth to any Bluetooth enabled speaker.
Iāll second Rugbyās recommendation. āChromecast built-inā or whatever they call it these days is pretty much as good as Roon Ready, and more likely to have Bluetooth. I use an Insignia battery-powered portable speaker outside, works well with Roon.
Thanks yāall. Iām grateful for the help. Iāll go the Sonos route per @Red_R 's suggestion, as I value the ability to group them in Roon. I think the neighbors will appreciate more speakers at a lower volume in lieu of one speaker playing loudly, as Iām not sure they share my affinity for yacht rockā¦
Iām so glad I found Roon, and this forum. Iām not in the same league of proficiency as most of you, but Iāve always been able to get good guidance from more experienced members, from building my Rock NUC to choosing endpoints. In a world of constant frustration, this place is a godsend. By the way, since Iām working with WiFi on the anticipated Sonos Moves, will changing routers improve the sound quality?
