Help With Outputting Roon ARC Audio (Building New Audio System)
I just started Roon this weekend and everything is awesome at home and in the car; I love the software.
When I brought my phone to work, though, I was absolutely shocked to find that Arc doesn’t support Chromecast (which is typically how I connect to the Google Speaker I’m currently using). I used Bluetooth, which obviously has its limitations, so I’m good for now.
I am working on a system for work with a set of bookshelf speakers and an amp. Does anyone have suggestions for getting the Roon Arc to work in a setup like this? I’m considering something like a Wiim Pro Amp (but I’m not totally sure a RAAT endpoint will work with Arc) or using something like a Raspberry Pi to run RoPieee (or something similar).
I haven’t found great documentation about the capabilities of Arc to connect to external devices, so if anyone can point me in the right direction or offer advice, it would be greatly appreciated.
You can use system Cast on Android phones and system AirPlay on iOS.
But there is no built-in CC/AP in the ARC app, so you are limited to the phone OS (and can’t use Chromecast on iOS, for instance).
E.g.,
If a cable is an option, you can also use USB to connect to any DAC/streamer that has a USB input
That’s useful (although I’m having some issues with the system Chromecast that I suspect have little if anything to do with Roon). It mirrors the screen display, but doesn’t carry over the audio.
Will ARC pick up valid Roon endpoints when it is on a different network than the Roon server (such that a Wiim of some type would work if plugged into an amp)?
No. ARC is intended as a phone app and the only output is to the phone default output (which can be phone speakers, Bluetooth, CC/AP, or USB, but this is up to the phone).
Specifically, it is NOT a solution to play to Roon Ready devices via RAAT.
Thanks for setting me straight on that one. I guess my solution will likely be an Android tablet running Roon ARC that I can connect via USB to the amp. You’ve saved me a ton of futzing around with the setup; I really appreciate it.
