Can you srnd me feedback? You can find that option on the advanced to tab
Logs haven been sent: 2bc51e78e560135a
Thanks for the quick response!
It reports failures when probing the HAT. So it does not initialise properly, hence no audio device, hence no show up in Roon.
Have you checked the physical connection of the HAT?
You were totaly right. It wasnāt attached properly⦠Strange cause, I tested this even with two different digi2 pro HATs. Really embarrassing.
Well, now both Piās are running with the HAT attached and working fine.
Thankās for your very fast help!
@spockfish My Digi2 Pro isnāt showing up in Roon since I updated to 4.017. Do the logs show what the problem might be? When I sent feedback it gave me this code: a44a221e11eeea1a.
edit: Rebooted my RPi for the umpteenth time, and now it works. Problem solved.
Hi there,
I have the same problem as above: Pi4 with Digi2 Pro shows up in Settings ā About but not Settings ā Audio, and therefore doesnāt work as a Roon endpoint. Iāve swapped out the Pi4 and tried with a brand new SD card, as well as changing the HAT to Digi+ and Did+ Pro in Ropiee⦠all with no joy. I also have an Allo Digione HAT that works flawlessly, so I assume it is not the Pi or the internet connection that is at fault. Any ideas? Would be extremely grateful for help, Iām fairly new to all of this.
Thanks in advance!
Have you tried the latest release?
Yes, I have. Downloaded fresh todayā¦
(Thank you for the hyper-fast response!)
ok, but then you should not have āhi-jackedā this thread, as this is about a different release.
Anyways, can you send me feedback? You can find that option on the āadvancedā tab in the web interface. I can then have a look at the logs.
Ah my apologies, sorry! As I said, new to all of this⦠Apologies for the false posting.
I will send feedback shortly. Would you rather I opened a new thread? Thanks!
No worries. Just post the identifier that you will get when hitting āsend feedbackā over here and I can have a look at the logs.
Ok! Here we go: 025ef087e893bca4
Thanks again
This is not the latest release.
Please use the new release (2022.02).
Ah sincere apologies, but thanks again. I really appreciate the help!
Another really dumb question Iām afraid ā where do I download the latest release? On the home page I only see the version from 2021/11/05ā¦
Really sorry for being such a noob here!
Iām wondering were you are looking:
Have you tried clearing your cache?
You are a complete hero. I think this has worked. Fabulous!
Iām afraid I spoke too soon. Doesnāt work at all still. Hereās the feedback e041c23adee465c0
Sorry for giving you such a headache today⦠:s
Hi similar problem here. New pi 4 with new hifberry digi2 pro hat, install of current (2022) version of ropieee, and Roon recognizes the pi in the āAboutā tab but there are no devices listed in the āAudioā tab.
feedback code: a2bbcae900704cfb
EDIT: once I plugged in my Chord Mojo into the USB slot of the pi, it showed up in Roon. However when I remove the USB and plug in a toslink optical to the hifiberry HAT, it disappears from Roon. Suggestions? I mean I bought the HAT to use optical or coax so not to use USB. I have selected HiFiBerry Digi2 Pro in the āAudio Hatā pull-down menu in the General tab of the RoPieee web control panel.
EDIT 2: I wonder if the HAT is not being detected as in this recent blog from hifiberry:
