HIFI Berry Digi2 Pro Not Working With Release 4.002
My hardware is a Pi4 with HiFi Berry Digi2 Pro and Roon Rock running on Intel NUC i3. In Ropieee V3 the Audio Hat was selected as HiFi Berry Digi Pro, and this worked.
I purchased the Digi2 Pro soon after its release and it has been working without a problem until the update to 4.002 last week.
Since the update to 4.002 the Digi2 Pro is no longer recognised in Roon. Under Settings About Ropieee is correctly listed showing Version 1.8 (build 806) stable. But, under Settings Audio Ropieee does not appear. At the bottom of the screen the message ā€œNo Audio Devices Foundā€ appears.
I have tried a brand new unused SD card flashed with a new copy of 4.002, without success. I have tried changing the Audio Hat setting in Ropieee between Digi2 Pro and Digi2 but no difference. Rebooting Roon and Ropieee makes no difference.
I have resurrected my old HiFi Berry Digi Pro card which will work correctly with 4.002 using the hat selection of Digi Pro or Digi2 Pro.
It seems that the problem affects only the Digi2 Pro card.
I wonder if there is a problem in Release 4.002 affecting the Digi2 Pro card.
Any help would be appreciated.
Regards, Bob
Bob — I’d suggest leaving Harry feedback (using the Advanced tab), in case the logs provide some useful information regarding what is going on for you.
Welcome to the Roon forum.
Feedback posted : 3d8b7e76d4bfdf1b
Bob
Hi @Robert_Pettener ,
So to be clear: you had it configured with the ā€˜Digi Pro’; that worked.
After the update you decided so set it to ā€˜Digi2 Pro’, as that is now available in RoPieee.
And it stopped working?
Anyways, I suggest you set it back to ā€˜Digi Pro’ for now; under the hood it uses the same driver. In the mean time I’ll try to figure out what’s going on.
Hi @spockfish
Just to clarify.
I have 2 HAT cards a Digi Pro and Digi2 Pro.
The older Digi Pro works with all versions of Ropieee and settings.
The Digi 2 Pro worked with V3 software with HAT set to Digi Pro (Setting for Digi2 Pro was not available in that release).
The Digi 2 Pro does not work with V4 software using any settings. It is not listed in Settings Audio and therefore cannot be selected as an audio device. It is listed in Settings About which would indicate this is not a network problem.
Thanks for your help
Bob
Ok thanks, clear now.
Have inspected your feedback a little bit more carefully and I also don’t see that it actually tries to load a driver.
Can you set it back to ā€˜Digi Pro’, save it (commit etc.), but do not reboot it but send me feedback right after.
@spockfish
Not sure I fully understand.
When the Digi 2 pro worked with setting of Digi Pro this was with version 3 software which I no longer have a copy of. I will do as you ask using version 4 and will post shortly.
Bob
Perfect, thanks.
@spockfish
Feedback posted: aa02bf95738d7d9f
Bob
Bob,
There’s a initialization error which points out to an hardware issue.
I see 3 possibilities: either the HAT is not properly attached, there’s a hardware issue with the HAT itself or something is wrong with the Pi.
Regards Harry
@spockfish
Harry, Thank you for your comments.
In trying to identify a hardware problem I have carried out the following checks:
  1. Connected the Digi2 Pro HAT to a Pi3 B+ running 4.002. All works as it should with HAT set to Digi2 Pro.
  2. Purchased a new Pi 4 as a test for the old Pi4. Connected new Pi4 to Digi2 Pro HAT and problem as before. Ropieee appears in Settings About, but does not appear in Settings Audio.
  3. connected new Pi4 to old model Digi Pro and all works as it should.
The problem combination is the Pi4 and Digi2 Pro.
I have now tried 2 Pi4 boards and tested Digi2 Pro card with a Pi3. I’m not sure if this still points to a hardware issue.
Before posting further feedback, I have changed the Hat setting in Ropieee to ā€œNo hat selectedā€ then Committ, Save and Reboot. I then changed Hat setting to HiFi Berry Digi2 Pro then Commit, Save but no reboot. Feedback reference 8576f22185a7f9c9
I appreciate the time you are giving and hope a solution can be found
Many thanks, Bob.
I’m a little bit confused: this seems like this is not a fresh install.
Are you swapping out SD cards?
I suggest you do a fresh install.
@spockfish,
Apologies I started with 2 fresh SD cards but I may have got them mixed up with all the swopping of Pi’s. I’ll have another go tomorrow with a fresh install and post feedback.
Thanks Bob
@spockfish
I’ve run the test again, Pi4 with Digi2 Pro using a fresh SD card. Feedback : 934ec7788a7cccde
Result was as before, Ropieee appears in Settings About, But is missing in Settings Audio.
For the time being I will revert to using a Pi3 B+ with the Digi2 Pro as this combination works ok.
Regards, Bob
Ok, I’ve ordered a Digi2 Pro myself to verify.
2 posts were split to a new topic: AUDIOPHONICS Digipi+ not working
I have the same issue, RPi4 and Digi2 Pro card. Installed and setup as instructed but don’t see the hat in Roon settings audio. (p.s. same as Robert… the Ropieee does appear in settings about)
Can you send me feedback so I can have a look?
@spockfish
A short note to finish the issue I started above.
I updated to Roon Rock 1.8 Build 831 released last week. I connected my Pi4 and HiFi Berry Digi2 Pro and am pleased to say that, after the Roon Rock update to build 831, everything is now working again. I did have to reboot Ropieee 3 times but the Digi2 Pro now appears in Settings/Audio as it should.
Thanks for your help.
Bob
Hello,
I got the same problem. Pi4 with Digi2 Pro results in showing up in ā€œSettings - Aboutā€ but not in ā€œSettings - Audioā€.
I tried two Digi2 Pro with the Pi4 (for the second Pi an upgrade) with the same result.
I’ve done severeal restarts of the Pi, an reboot of the ROCK, reinstalling Roon Bridge via Web Interface and reflashing the SD-Card and updating from version 4.017 stable to 4.018 beta.
Is there something else i should try?
