I just downloaded the latest version and am trying Roon as a trial version. I clicked on a song in a Tidal Masters playlist and got this horrible repetitive noise on top of the song. Playing it through my iMac and headphones attached. Non masters songs are not doing it and some masters songs don’t do it. It’s a horrible sound.
Sounds like the old bug with 24/48 playback on MacOS in non-exclusive mode. Check if you have Exclusive mode switched on, and if not, select it and see if the problem goes away.
Hi @Jason_McCarty ---- A new RAATServer folder is generated upon relaunching the application. This is expected behavior.
Have you tried using “exclusive mode” yet? Please enable “Built-in” under the “audio” tab, select “device setup” by clicking the gear next to the zone, and engaged “exclusive mode” under the “playback” tab.
