Installed roon to pc and use it as cord and when I sign in the account roon shows “Your screen is too small to run roon. Please try to run Maximized or fullscreen”
once become full screen after click “fullscreen” I can not use pc other app! need sign out roon to use PC.
What should I do? is there any adjustment?
Thank you
Just wanted to follow up with you here if you’re still having this issue, Roon requires a 1440 x 900 minimum resolution to operate properly as per our documentation. You may also want to increase your PC’s resolution if it does not meet that minimum.
