Corsair Virtuoso Wireless RGB SE
Connected via USB-C. Supposedly would support 24-bit/96kHz.
When I play any music, Tidal or not, Roon just skips each one of them until the last. Nothing gets played. When I change the audio output to my speakers, Roon plays just fine… perplexing!
You use the 2.0 Channel Layout in Roon. When you set it to 7.1, does it change anything?
Is Windows using the headset as standard output device? This might not work then in conjunction with Exclusive Mode = Yes in Roon.
