Thanks David. I really appreciate your openness and willingness to accept the findings.
This reminds me of the episode about Johannes Kepler in Carl Sagan’s Cosmos. Kepler had been looking for supernatural explanations of the movements of planets, but when the observations of Tycho Brahe, which were the most accurate at the time, proved all his theories wrong, he had to throw everything away and start from scratch. The result was something way less exciting: ellipses. He gave up the occult and embraced science. No parallels to actual living persons…
My understanding is that this is also Diretta’s theory, at least in concept, so I believe this invalidates the reasons for its existence.
I’m not sure I agree with that. When people compare different setups and decide which one is “better” - whatever that means - they probably focus more intently on the novel solution than they used to with their current setup. This heightened focus may, by itself, explain why people hear more details than before. And that’s why I think it’s important not to forget to go back to the previous setup with the same level of focus, before jumping to conclusions.
Take for example the classical experiment with the same wine in different bottles with different price tags. You can say people appreciate the “more expensive” wine because they’re snobs. But you could also say they genuinely enjoy the “more expensive” wine because it commands more of their attention and thus they focus more on its qualities. When you do blind tests, not only do you remove potential bias, you also level the playing field in terms of focus. Bottom line, I think focus is key; it’s called critical listening for a reason.
Regardless, I may have had to persuade my sons to do it (and still need to do it to complete the last phases), but once they started, they did it at their own leisure and did their own switching, without me being around, so I don’t think there was any pressure.
I can understand the engagement, as I explained above. Now that there is some objective data in the mix, some of the listeners may be less inclined to take Diretta’s claims at face value and more open to the possibility that’s it’s just the excitement of a new toy.
I’ve looked at the power rail noise across the audible spectrum. The oscilloscope may not be that accurate in terms of FFT. I think I can do a more thorough analysis of the frequency components using the ADC. I’ll post the results back in the measurements thread when I have them.
If that’s the case, wouldn’t a well engineered DAC be the natural solution to whatever the problem Diretta is trying to solve? The D70 is not an expensive DAC, so it’s possible to do it at affordable prices. Hi-fi is a commodity.
