Hi David.
Been playing around with the setup and so far seems better than other sources.
That said, was wondering what, if any, maintenance needed to be done periodically.
Going thru the host and/or target menus, observed both Update kernel and Update system options, with kernel cautioning to do system first. Did both updates on host and target in suggested order and now Roon is not seeing the device(s).
Sorry to be a pain but I’m stumped. Figured providing “Show configurations” would be good first troubleshooting step. Pasting below.
Thanks for any help!
############ START OF PASTE ####################
│ AudioLinux main menu - version 533 │
│ Audiolinux original version 5.1.0 │
│ KERNEL: 6.12.77-1-rpi+ RT LTO │
│ CPU: Cortex-A72 │
│ MEMORY: 1 GiB │
│ KERNEL TIMER FREQUENCY: 1000 Hz │
│ KERNEL EXTRA CMDLINE PARAMETERS: audit=0 irqaffinity=0,1,2,3 │
│ KERNEL CONFIG PARAMETERS: dtoverlay=disable-wifi │
│ dtoverlay=disable-bt │
│ otg_mode=1 │
│ CPU FREQUENCY: │
│ Scaling driver: cpufreq-dt │
│ Governor: performance │
│ Frequency min.: 600000 kHz configured: 1500000 kHz │
│ Frequency max.: 1500000 kHz configured: 1500000 kHz │
│ OVERVOLTAGE: 0.8700V │
│ IRQ balance: disabled │
│ LINUX JOURNAL: enabled │
│ ISOLATED CORES*: │
│ disabled │
│ REALTIME PRIORITY*: │
│ IRQ priority enabled │
│ IRQ with realtime priority │
│ 90 irq/29-xhci_hcd │
│ APPLICATIONS │
│ 80 RoonBridge --debug --gc=sgen --server RoonBridge.exe │
│ HARDWARE CLOCK: available: arch_sys_counter used: arch_sys_counter configuration: │
│ SYSTEM CLOCK SYNC: chronyd │
│ RAMROOT: Active: no - Configured: no │
│ LOOPBACK: disabled │
│ MUSIC2RAM: disabled │
│ DELAYED AUDIO SERVICES: not configured │
│ SAMBA: disabled │
│ WIFI: disabled │
│ BLUETOOTH: disabled │
│ HDMI/VIDEO: disabled │
│ MAC SPOOFING: disabled │
│ NETWORK/USB NO POWER SAVING: disabled │
│ REMOVED USB DEVICES: disabled │
│ WEB INTERFACE enabled │
│ HOSTNAME diretta-host │
│ AudioLinux main menu - version 527 │
│ CPU: Cortex-A76 │
│ MEMORY: 2 GiB │
│ otg_mode=1 │
│ CPU FREQUENCY: │
│ Frequency min.: 1500000 kHz configured: 2400000 kHz │
│ Frequency max.: 2400000 kHz configured: 2400000 kHz │
│ OVERVOLTAGE: 0.8924V │
│ disabled │
│ 90 irq/129-xhci-hcd:usb1 │
│ 90 irq/134-xhci-hcd:usb3 │
│ APPLICATIONS │
│ 80 /opt/diretta-alsa-target/diretta_app_target /opt/diretta-alsa-target/diretta_app_target_setting.inf │
│ SAMBA: disabled │
│ WIFI: disabled │
############ END OF PASTE ######################
BTW: Could NOT figure out how to capture output without including “menu’s framing”. Sorry…
