I am a new user and i have some issues with the audio output selection. On two of my remote devices i do not find the audio output of that specific device, so for example on my ipad when i access the audio zone selection i do not see the local output. The other remote where i have this issue is a recent (<6 months old) dell xps. I do not have this issue on an older laptop.
I am using roon version build 99 on the server and pc remotes and build 94 on the ipad
All material in the chain have been updated with the latest versions as of today
The quick answer is that you cannot output on an IOS device’'s headphone jack, it can only to be used as a control point. There are technical reasons caused by IOS itself. If you want a tablet that can also output to headphones go Android.
ok thank you did not know that and did not see that one, now just solving the pc issue then. I have for your info also tried on an older android samsung tab2 but apparently roon does not work with that one
As I understand it If you give the Realtek Digital Output a name it will then show up as an audio zone to play music.
This should then show up on your iPAD.
Yes, but Patrick is looking for Private zones connected to the iPad and a laptop, not zones connected to the Core. The iPad doesn’t have Private zones yet. The laptop should have some, depending on what audio devices are running on the laptop and whether it has USB drivers installed etc.
