Incorrect track sequencing and unidentified albums for The Beatles and Sun Kil Moon (ref#P3URCN)
· For some inexplicable reason Roon has decided that the Beatles White Album is unidentified.
It has also decided that the track sequencing should be track 1 from CD1 followed by track 1 from CD2 followed by both tracks 2 and so on.
These CDs come from the Beatles box set from around 2015-16. There has been no problem with identifying or sequencing since I ripped them around 2017-18. I have used Roon since 2016.
There is a similar problem with April by Sun Kil Moon. When I started listening to this yesterday the track sequencing was correct & it was clearly identified with a review etc.
Around half way through track 1 I noticed that the track sequencing had changed to track 1 CD1 followed by track 1 CD2 etc. Then it became unidentified. Today it is identified but the track sequencing is still incorrect.
All my other double or more CD sets sequence correctly whether ripped to my server or streamed from Tidal.
I use a Rockna Wavedream Light server with a Wavedream reference DAC.
I am at a loss. I have changed every import settings from file to Roon & back again. It makes no difference. I have tried changing everything I can think of.
I have used Roon on 5 different servers with no problems with track sequencing. I don’t worry about user data so the listen count is only on this server which is about 3 months old.
· Router is a true gigatex fiber my iPad has a Norton VPN no switches
Hello @Neil_MacInnes
Thank you for reaching out to Roon support,
It might be helpful to have the file(s) for testing on our end as well. Could you please zip and upload them here and let us know?
Hi, Have zipped the files for the white album (archive.zip) and uploaded it as requested.
Neil
Hi @Neil_MacInnes,
Thanks for uploading the files, that gave us exactly what we needed, and we can now explain both problems. They’re the same problem, and it’s in the tags rather than in Roon.
What we found
Every track in your The White Album (CD1) folder is tagged like this:
Album = The White Album (CD1)
Track = 1–17 of 17
Disc number = 1 of 1
The CD2 folder is tagged the same way, disc 1 of 1. When these were ripped, each disc was written out as its own standalone single-disc album, and the only thing distinguishing them is the “(CD1)” / “(CD2)” text in the album title. The disc number fields were never set to 1-of-2 and 2-of-2.
Roon correctly recognizes the two folders as one two-disc set and combines them into a single 30-track album. But once combined, both halves claim to be disc 1, so there’s nothing to sort them by except track number, which produces exactly what you’re seeing: CD1 track 1, CD2 track 1, CD1 track 2, CD2 track 2, and so on. Your Roon Server logs show it plainly:
Playing: .../The White Album (CD1)/01 ... Back In The U.S.S.R..flac
Queueing: .../The White Album (CD2)/01 ... Birthday.flac
Queueing: .../The White Album (CD1)/02 ... Dear Prudence.flac
Queueing: .../The White Album (CD2)/02 ... Yer Blues.flac
The failed identification follows from the same cause. Because the album presents itself as a single disc with 30 tracks, it doesn’t match any real release, so identification can’t succeed. We can see this directly in your logs from 2 September: while you were experimenting with folder names, Roon briefly saw the 17 tracks on their own and identified them within two seconds. The moment it was back to 30 tracks, identification failed again.
April by Sun Kil Moon has the identical issue, April CD1 (11 tracks) plus April CD2 (4 alternate versions), both tagged disc 1 of 1, combining into a 15-track album that can’t be identified. That also explains why the sequence seemed to change partway through listening: playback started in the main album and then crossed into the CD2 files.
For contrast, your Delicate Sound of Thunder and Sgt. Pepper’s sets use the same folder layout and play in the correct order, because their disc numbers were tagged properly.
Why the settings changes didn’t help
Switching an album between “Prefer File” and “Prefer Roon” won’t change anything here. Those settings choose between Roon’s metadata and your file tags, but an unidentified album has no Roon metadata to choose, so the file tags are used either way.
Two ways to fix it
The quickest fix, with no re-tagging, is inside Roon:
  1. Select the album, click the three-dot menu, and choose Edit
  2. Choose Fix Track Grouping
  3. Assign the CD1 files to disc 1 and the CD2 files to disc 2, in track order
  4. Then use Identify Album to match it
The more durable fix is to correct the tags themselves, using something like Mp3tag or dBpoweramp’s tag editor:
  • CD1 files: disc number 1, total discs 2, track total 17
  • CD2 files: disc number 2, total discs 2, track total 13
  • Both: set the album title to the same value on every track — remove the “(CD1)” and “(CD2)” suffixes
Then rescan the folder. Roon will combine, order and identify the set correctly.
We’d suggest applying the same fix to April, and it’s worth checking any other multi-disc sets you ripped in that same era, the “(CDn)-in-the-album-title” pattern tends to repeat across a rip session, so there may be a few more waiting to surface.
One unrelated thing we noticed while reading the logs: your iPad is refusing audio connections quite persistently. If you use it as a playback zone, the VPN running on it is the most likely cause. Happy to look at that separately if it’s giving you trouble.
Let us know how the above goes.
