Inquiry about sound quality difference between Nucleus One and Titan (ref#XUJQM0)
· Other – My issue isn’t listed above
I have a
Nucleus One. I have a question. Does the Titan have better sound quality than the One? My system is pretty simple but very nice sound. dCS Rossini DAC and Rossini Wordclock driving McIntosh MC1.25KW’s amps. Restating the question would the Titan have a better sound? Thanks.
Not an issue
In a nutshell, no. Both are computers streaming digital media to an external DAC. Roon’s best practice guidance is to use Roon server (on the Nucleus) plus a network streamer, which has a direct connection to the Rossini. Both Nucleus and streamer should be connected to the same network using Ethernet.
Hello @Jeff_Ronan ,
Sound quality wouldn’t be a primary factor when choosing between the Nucelus One or a Titan. While we generally don’t comment on Sound Quality, you can look over the below guide to get a sense of what makes great sound quality systems:
Since both the Nucleus One and Titan are dedicated Roon Servers and you’re playing to Roon Ready zones, then you would have minimal interferance. The one thing to keep in mind though is if you are performing heavy DSP (upsampling to DSD/Convolution/Many zones at the same time), then the Titan would be better equipped to handle this compared to the Nucleus One.
