Installing ffmpeg on ROCK problem
I am tryng to install the ffmpeg but still missing codecs appears on the ui interface I downloaded the ffmpeg and unzipped and paste it into the rock[ s codecs folder but no changes
You need to unzip the result of the first unzip and then move only the ffmpeg module.
It should be around 76-77 MB.
Another potential reason…
Are you using Linux? If so see
