Roon lost connection to denon ceol sometimes. At fist time all was fine, but sometimes Roon doesn’t see denon ceol at tab Audio at settings. Roon running at Mac mini at same network where ceol. I set fix ip. And I can’t add manually Ceol to Roon(
This helps our team gather all the necessary information to solve your issue as quickly as possible. Thank you!
AceRimmer
("I’m not just a hero; I’m a legend!")
2
Hi
This thread indicates you might require assistance from Roon technical support.
Respond to the prompts there to ensure that you’ve performed basic troubleshooting and to ensure Technical Support has the full details necessary to expedite Technical Support’s investigation into the case.
Your responses will auto-generate a Community thread in the appropriate section.
Because this Community thread will be in a public forum, please do not include any personal information, such as your email address, postal address or telephone number in your submission. Thank you.
· A connected audio device is not appearing in Roon
· Network - Ethernet
· RoonReady
· No, it does not show up there
Since you are using a network connection to the device, please ensure that your RoonServer is on the same subnet as the device
· My devices are on a single subnet but is not visible to Roon
· I have a *mesh network* with devices connected to multiples points
Your local network might need some re-arranging to support Roon.
· None of the suggestions have helped me. I'd like to submit a support request.
· no
· Denon Ceol n10 wired connected to Buddy 6, Roon at Mac Mini using Wi-fi.
Roon lost connection to denon ceol sometimes. At fist time all was fine, but sometimes Roon doesn’t see denon ceol at tab Audio at settings. Roon running at Mac mini at same network where ceol. I set fix ip. And I can’t add manually Ceol to Roon( I use Keenetic Giga + Keenetic Buddy 6
My network based at Keenetic Giga with 2 reppiter Keenetic Buddy. Whey have same subnet without firewall ot etc
As a first step in troubleshooting, could you please temporarily connect your Denon directly to your primary router via ethernet, and see if the same issues occur?
With that, what OS are you currently running on your mac running Roon Server?
macOS Sequoia (version 15), has tighter (and more obfuscated) network security settings than preceding MacOS versions.
Can you please navigate to macOS System Settings > Privacy & Security > Local Network, and make sure Roon and Roon Server are allowed.
If it is already enabled, toggle it off and on again. Then reboot your Mac, and see if the same issue persists.
Let me know if either of the above help - thank you!
I’m turn off all buddy and connect Ceol through Wi-Fi to core router, also check at Mac network permission settings, but still not see Ceol at Roon. Unfortunately last connection was menu times ago.
At least one of your Roon Remotes is running an outdated version of Roon - please update to the latest available build on all Roon devices in your ecosystem.
What is the specific pathway between the Denon and Roon? Do you have any access points, managed switches, mesh nodes, etc in between?
Please ensure that multicast forwarding is enabled in your router settings. It sounds like you’re relying on a WiFi connection for the Ceol; try restricting the WiFi network to a single band (2.4GHz) or turning of band steering, if that setting is available.
About
Roon Remote
恩
This Mac O
Roon version 2.56 (build 1582) production - Read change log
You have the latest version installed.
Roon Server
This Mac O
Roon Server version 2.56 (build 1582) production -
Read change log
Thx for all, now all works fine.
To solve this issue, as a recommended, im connect Denon Ceol direct to router through wire and Roon detect Denon Ceol. Now all work at Wi-Fi correct.
Sorry for our delayed response here. We’re glad to hear the issue is resolved and grateful that you’ve taken the time to share your solution here for the community.
