· I have a Matrix Audio NT-1 Streamer. I start ROON it sees the NT-1 sometimes on the network. If i play a radio or album it plays for 1 sec then skips to next song then evetually says "too many errors" and just stops. Tidal/Qobuz connect have zero problem with this at all only ROON sucks and is unable to main a connection. What is going on with your product. Heck even the rudimentary control app for the NT-1 can connect and play all day long. Not ROON nope.
· I dont use a VPN. The streamer is connected to the internet via a wireless beidge then wired to a LHY FMC to SFP to the streamer. Sold connection and ultra quiet. I have a Netgear router and no im not going to start listing model numbers etc
Hmm so no help so far. So much hope for this app and it is unusable.
Hey @George_Collins,
Thanks for your patience, and sorry for the slow response. We’ve gone through the diagnostics from your Roon Server, and they line up exactly with what you’re describing.
Each time a track plays for about a second and skips, Roon is failing to sync its clock with the NT-1. After several failures in a row, playback stops with “too many errors.” When the sync does succeed, the stream still drops out after about a minute. Your Rose RS130 on the same Roon Server syncs every time with no dropouts, so the Roon Server itself looks healthy. The problem is in the network path to the NT-1.
Two things stand out:
- The NT-1 is on the network twice, at both 192.168.y.21 and 192.168.y.26, with the same device ID. That usually means Wi-Fi is still enabled alongside the wired/SFP connection. It would also explain why Roon only sees the unit some of the time.
- Roon’s clock sync uses UDP traffic on your local network, and wireless bridges are a common reason that traffic gets dropped. Tidal Connect, Qobuz Connect and the Matrix app stream straight from the internet over a different kind of connection, which is why they aren’t affected.
Could you try these steps in order?
- In the Matrix app, turn off Wi-Fi on the NT-1 so it only uses the wired/SFP link, then restart it.
- On your RAX45, set a DHCP reservation for the NT-1 so it keeps one fixed address.
- As a quick test, temporarily connect the NT-1 by Ethernet directly to the router, skipping the wireless bridge, and try a few albums and a radio station. If it plays cleanly that way, we know the bridge is the culprit. Then check that the bridge is in a true bridge/client mode, not running its own routing or NAT.
- Make sure the NT-1 has the latest firmware from Matrix.
If you still see skips afterwards, please tell us the local time it happened and which step you were on, and we’ll take another look at fresh diagnostics.
