Intermittent dropouts and playback stops on Ethernet-connected system using Roon (ref#EUAFRS)
· Ethernet
· The issue *only affects one file *format.
Which format is giving you trouble?
· FLAC
· It is connected through a different device (e.g Rasberry Pi)
· Only one output type is affected while the other output type works as expected
· This morning at about 10:15 am
· Devialet Expert Pro 220 integrated amplifier
I have an ethernet connected home network that plays music as using the following system:
TP-Link Tri-Band Router Model BE9300 (Archer BE550).
Nucleus Plus server (79,009 FLAC songs on an 8TB Samsung SSD hard drive).
The Nucleus Plus server is connected directly to the router with a 3 ft ethernet cable.
A 15 ft ethernet cable goes from the router to a Netgear 8 port gigabit ethernet switch (Model:GS308v3).
An 4 ft ethernet cable goes from the Netgear ethernet switch to an Ethergen ethernet switch which is connected to an After Dark CKAYX10 MHZ Emporer clock.
A short 1 ft ethernet cable goes from the Ethergen switch to a Devialet Expert Pro 220 integrated amplifier.
Music playing is controlled by the Roon app downloaded to my Apple i-phone 17
About two weeks ago I began having 1 or 2 second dropouts throughout a song while it was playing. The dropouts have now progressed to the song stopping at different points while it is playing. When it stops I can get it to play again by pressing the "Play/Pause button on my Roon app on my i-phone. I replaced the ethernet cable connecting my server to my router with a new one & I adjusted Roon's playback buffer size to 100ms but these measures did not help. Can you help me to try to solve this problem?
As described previously
Hi @Greg_Johnson,
We’ve checked the logs from your Nucleus+. The Nucleus is reading and sending your FLAC files without problems. What we see instead is the Devialet Expert Pro dropping its connection to Roon, often several times an hour (for example, every 1–3 minutes on the evening of 22 November). After each drop, the Devialet refuses new connections for a short while before it comes back. That matches the dropouts and stops you’re hearing, and it’s why a bigger buffer didn’t help.
Since this happens on the Devialet’s side of the link, please try:
  1. Power the Devialet off at the mains for a minute, then back on.
  2. As a test, connect the Devialet directly to the Netgear switch, bypassing the EtherREGEN and the clock. Leave it that way for a day or two and see whether the dropouts stop.
If the dropouts stop, the issue is in that last part of the chain. If they continue with the Devialet connected directly, it’s worth contacting Devialet support with the details above, and we can share what we see on our side.
