Intermittent DSD crackling with PS Audio Nucleus setup via I2S connection (ref#NR3CKC)
· Psaudio airlens, dac psaudio perfectwave directstream mk2 reliés en i2s avec cables audioquest vodka 48 de 0,75 metres. Problème de crépitement en dsd. J'ai le roon nucleus one. Si je passe en coaxiale et reviens en i2s, le problème s'arrête et recommence un peu plus tard. J'ai essayé plusieurs paramètres trouvés sur internet. Je m'en remets à vous. Merci.
En amount, switch Networks acoustics et filtre muon pro..
· Router helix videotron, switches Networks acoustics Tempus with filter muon pro
(Translated by Google)
I have a PS Audio AirLens and a PS Audio PerfectWave DirectStream DAC Mk2 connected via I2S using 0.75-meter AudioQuest Vodka 48 cables. I am experiencing crackling issues with DSD playback. My setup includes a Roon Nucleus One. If I switch to coaxial and then back to I2S, the problem stops, only to recur a short while later. I have tried various settings found online. I am turning to you for help. Thank you. Upstream, I have a Network Acoustics switch and a Muon Pro filter.
Hi @Dany_Levesque,
Thanks for the details. Intermittent DSD crackling over I2S can come from a few different places, and the fact that it clears when you switch away from I2S and back suggests we should look at the signal path, the endpoint handshake, and the network path between the server and the AirLens.
First, could you check the Signal Path while the crackling is happening and let us know whether Roon is showing any sample rate conversion, DSP, or unexpected format changes? If the path is showing DSD all the way through, that will narrow this down a lot.
Next, please try the AirLens with no switches or filters in between for one test, if that is practical, just to see whether the Network Acoustics gear is part of the trigger. The other thing I’d like to confirm is whether this happens with every DSD track or only certain albums and sample rates.
Finally, if you can note the exact time and one affected track the next time it happens, we can compare that against diagnostics after we enable them on your account. A timestamp plus the track name is usually the fastest way for us to line up the playback event with what the server was doing.
Thank you, and let us know what you find.
Bonjour @Dany_Levesque,
Merci pour ces précisions. Les craquements intermittents en DSD via I2S peuvent provenir de plusieurs sources ; le fait que le problème disparaisse lorsqu’on quitte l’entrée I2S pour y revenir suggère qu’il faut examiner le chemin du signal, la négociation de connexion (handshake) avec le point de lecture (endpoint) et le trajet réseau entre le serveur et l’AirLens.
Tout d’abord, pourriez-vous vérifier le « Chemin du signal » (Signal Path) au moment où les craquements surviennent et nous dire si Roon indique une conversion de fréquence d’échantillonnage, l’utilisation du DSP ou un changement de format inattendu ? Si le chemin indique du DSD de bout en bout, cela permettra de restreindre considérablement les causes possibles.
Ensuite, veuillez essayer d’utiliser l’AirLens sans aucun switch ni filtre intermédiaire pour un test (si cela est réalisable), afin de déterminer si le matériel Network Acoustics joue un rôle dans l’apparition du problème. J’aimerais également savoir si ce phénomène se produit avec tous les titres DSD ou seulement avec certains albums et fréquences d’échantillonnage.
Enfin, si vous pouvez noter l’heure exacte et le titre concerné la prochaine fois que cela se produit, nous pourrons comparer ces informations avec les données de diagnostic une fois que nous les aurons activées sur votre compte. Un horodatage accompagné du nom du titre est généralement le moyen le plus rapide pour nous de corréler l’événement de lecture avec l’activité du serveur.
Merci, et tenez-nous au courant de vos constatations.
Le filtre muon pro, n’est pas en cause pour l’avoir enlevé pendant l’écoute. Il s’agit de l’album plus bas. Il est enmagasiné sur ma carte ssd dans mon nucleus. L’ecoute de 14h35 à 14h45.Il m’est arrivé que le dac cesse completement la lecture. Je n’ai que 2 albums en dsd et le probleme est le meme à l’ecoute des deux. Je n’avais pas ce probleme sur mon dac luxmand-150. Je pensais pas avoir ce problème. J’avais choisi psaudio parcequ’il était certifié roon ready.. Le problème etait le meme en usb? J’avais lu sur internet que le probleme serait surement reglé en passant par psaudio airlens.
Hi @Dany_Levesque,
We’ve check the Roon Server logs from your session on October 8, 2:35 to 2:45 PM. They show the Verdi album playing as native DSD128 with no conversion, no buffering problems, and no network errors. Roon delivered a clean DSD stream to the AirLens the whole time the crackling was happening.
In your setup, audio travels from the Nucleus over the network to the AirLens, then from the AirLens over I2S to the DirectStream Mk2, which converts it to analog. The logs confirm the first part of that chain is clean, so the problem is happening after the signal leaves the AirLens, at the DAC.
The crackling happens over both USB and I2S, and the same albums played fine on your Luxman DAC. Both point to the DirectStream Mk2’s DSD playback. Please contact PS Audio support, mention both points, and include the firmware versions of the DirectStream Mk2 and the AirLens.
If the DAC stops playing completely again, please note the date and time so it can be checked against the logs.
Pour votre écoute du 8 octobre, entre 14 h 35 et 14 h 45, les logs du Roon Server indiquent que l’album de Verdi a été lu en DSD128 natif, sans aucune conversion, sans problème de buffer ni erreur réseau. Autrement dit, pendant toute la durée des crépitements, Roon transmettait un flux DSD intact à l’AirLens.
Dans votre installation, le signal part du Nucleus et transite par le réseau jusqu’à l’AirLens, qui l’envoie ensuite en I2S au DirectStream Mk2, où il est converti en analogique. Puisque les logs confirment que cette première partie de la chaîne est propre, le problème se situe en aval de l’AirLens, au niveau du DAC. Deux autres éléments vont dans ce sens : les crépitements se produisent aussi bien en USB qu’en I2S, et ces mêmes albums étaient lus sans problème par votre DAC Luxman. L’origine probable du problème est donc la lecture DSD du DirectStream Mk2. Veuillez communiquer avec le support technique de PS Audio en leur mentionnant ces deux éléments et en précisant les versions de firmware du DirectStream Mk2 et de l’AirLens.
Si le DAC devait de nouveau interrompre complètement la lecture, veuillez noter la date et l’heure de l’incident afin de pouvoir les comparer aux logs.
