QNAP TS-473
TP-LINK VR2800 Router
Netgear Gigabit Switch
CAT 5E Cabling throughout
Example end-point (but same happens on Sonos end-points too):
Pro-Ject Stream Box S2 Ultra
Pro-Ject Pre Box S2 Digital
I THINK this issue is ISP related as I am seeing other performance issues with internet access, but I’m hoping replies here could help me to confirm that I’m barking up the right tree so to speak…
Internet Radio has always been stable, but in the last few days has been very inconsistent. Several channels on several end-points will play for a random number of minutes, then simply stop. Sometimes I see a “Roon has lost control…” message if I happen to be looking at my screen at the time. Playing files from my library (including Tidal) seems to be working fine.
My ISP (British Telecom) are saying they have no faults or issues on the WAN, my TP-LINK router isn’t reporting any drop-outs or issues so I am at a bit of a loss and am hoping someone here can give me some suggestions of things to try, or at least help me confirm that it is an ISP / WAN problem.
Playing the same Internet stations directly via the Sonos app behaves the same way, but Roon at least gives me access to some detailed logs!
I snapped this from the logs when it happened just now:
07/19 11:28:22 Info: [Daves Room Stream-Box-s2-Ultra] [zoneplayer] Playing: channel://icy%3a%2f%2fbbcmedia.ic.llnwd.net%2fstream%2fbbcmedia_radio4fm_mf_p%3fs%3d1563524519%26e%3d1563538919%26h%3d7c751eaa797708f51613d96e8d3dbc32
07/19 11:28:22 Trace: [Pro-Ject Audio Systems Stream Box S2 ultra @ 192.168.1.100:41035] [raatclient] GOT [11] {"status":"OutputMessage","message":{"signal_path":[{"method":"usb","type":"output","quality":"lossless"}]}}
07/19 11:28:24 Info: [Daves Room Stream-Box-s2-Ultra] [zoneplayer] Open Result (Playing):Result[Status=Success]
07/19 11:28:24 Info: [Daves Room Stream-Box-s2-Ultra] [zoneplayer] Aborting play because track changed
07/19 11:28:24 Warn: [streammediafile] error reading stream: Unable to read data from the transport connection: interrupted.
07/19 11:28:24 Info: [audio/env] [zoneplayer] All streams were disposed
07/19 11:28:35 Trace: [roonapi] [apiclient 192.168.1.108:43716] CONTINUE Changed {"message":"Running (855)","is_error":false}
07/19 11:28:35 Info: [stats] 2695mb Virtual, 574mb Physical, 283mb Managed, 0 Handles, 62 Threads
ANY feedback, help or tips on how to debug would be gratefully received as I’m not sure where to go next!
Thanks.
